Raise Z-axis Before Going Home
Specify the distance to raise the Z-axis before moving to home
Specify the amount to raise the Z-axis before moving home
This dialog appears when the following is true:
The dialog lets you specify an amount to raise the Z-axis, before the nozzle moves to the home position. You would use this if you had fixturing that might strike the nozzle while it moved home. You might also raise the nozzle if the material you were working with was uneven, or had raised sections.
