Arc Flip
Flips the direction of an arc without moving the end points
Right-click commands
The Arc Flip command changes the direction of an arc without moving either of the endpoints of the arc. By dividing an arc at appropriate locations, and then flipping the arc, complex shapes can be created easily.
The arc on the left was divided, and then each arc was flipped
How to Use Arc Flip
1. Right-click the Circle button and select "Arc Flip."
The cursor changes to the Arc Flip cursor:
2. Click the arc to be flipped.
The arc is flipped and you can now choose another arc.
3. When you are finished flipping arcs, press Esc to return to the default Zoom command.
