Whenever a number is needed, or can be supplied, LAYOUT will ask for input using an Edit Box. Although the Edit Boxes look different, they all function in the same way.
A sample dialog box
At any Edit box that is asking for numeric input, expressions such as (5/2+sin(90)) can be entered. (See Math Functions for a complete list of supported functions.)
If an Edit box turns yellow, then the number entered is inconsistent with the context (for example, "-1" was entered for the number of copies).
A circle cannot have a negative diameter
If an Edit box turns Red, an impossible expression has been entered, such as "100 / 0" (division by zero).
Dividing by one is undefined
Cut-and-paste to and from the Edit boxes
For example, you can copy the results of the Measure command by selecting the text, and pressing Ctrl+Insert. Then paste this information into other Edit boxes, like the one for the command. Suppose a line is 5.7647584" long, and it needs to be exactly 5" long. Use the , or command to find out its length, then copy 5.7647584 into the clipboard. Next choose and enter "5/" and press Ctrl+V to paste so it reads "5/5.7647584"
You cannot use Ctrl + C to copy from Edit boxes. Use Ctrl + Insert instead.
When a dimension such as 18 5/8 is entered, it must be entered with no spaces, like this: "18+5/8". Do not enter "18 5/8." If "18 5/8," is entered, the space is ignored, and the expression evaluated is actually "185/8" (which is 23.125).
