Rotate
Rotate selected entities
Right-click commands
The Rotate command rotates the selected entities counter-clockwise around a specified point. The entities can be rotated visually using the cursor, or by entering a specific angle of rotation.
How to Use Rotate
1. Use the Select command to select the entities to be rotated
If at least one entity is not selected when the Rotate button is clicked, then all entities in the drawing are automatically selected.
2. Click the Rotate button.
3. Specify the location of the rotation point.
The Snap toolbar appears. Use these tools to specify where the rotation point will be.
NOTE:
You can also click the left mouse button anywhere on the drawing to specify a rotation point.
Use the Snaps toolbar to specify the rotation point
4. LAYOUT prompts you for the angle of rotation in degrees.
There are two ways to specify the rotation of the selected entities:
Enter the number of degrees to rotate the selected entities
