Arc
Arc Flip
Arc Flip Selected
AutoPath
Box
Center
Circle
Continue
Create Bridge
Create Tab
Divide
Ellipse
End
Fillet
Lead i/o
Line
Middle
Near to
None
Polygon
Select/Deselect Special Command
Selected Limit Sna
Set Zero
Shapes
Sketch
Stretch Arc
X, Y pos
Zero
Draw commands create new objects
The Draw commands create new objects. In LAYOUT, all objects are composed of entities, which are either lines or arcs. Thus, even though there's a Box command, when you draw a box, you are really creating four line entities. This distinction becomes important when you use the Edit commands (to erase a box, for example, you need to select the four line entities that make it).
Most command buttons allow access to a variety of similar commands by right-clicking on the button. For example, if you right-click on the “Circle” command, you will find different commands for drawing circles, ovals, arcs, and curves. Buttons that have right-click options are indicated with a small red triangle in the upper right corner of the button. See figure below for examples.
Again, if you are interested in a particular command, click on the button in the following figure for details. For now, though, you don't need to know the specifics of the commands.
These commands create new objects
